Activity Forums Apple Final Cut Pro Legacy possible to render out a lower third graphic with alpha channel from FCP?
  • possible to render out a lower third graphic with alpha channel from FCP?
    Posted by Tad Newberry on June 22, 2012 at 6:43 pm
    i know i should make this in Motion (don’t have AE), but for a few reasons, it was better made in FCP. i built a nice lower third graphic with several layers, and wonder if there is a way to render it out as a single layer graphic and plop it on my FCP timeline? i know about nesting layers, but i mean to render this out once as a single layer lower third with alpha channel…
    thanks for helping out a bonehead!
    __________________________
    FCS3
    2.66 GHz Quad-Core Mac Pro
    6GB RAM
    NVIDIA GeForce GT 120
    …and a few TeraBytes o’ storage
    (then it’s on to PetaBytes, ExaBytes and MosquitoBytes!)
    Neil Ryan replied 14 years, 2 months ago 4 Members · 4 Replies
  • Shane Ross
    June 22, 2012 at 7:01 pm
    You need to use a ProRes 4444 timeline, as that is the only codec that supports embedded alphas. Make sure that the settings are set for Millions + colors. Then export. And the export needs to be ProRes 4444.
    Shane
    Little Frog Post
  • Kylee Pena
    June 22, 2012 at 7:03 pm
    I believe you could make your sequence with the lower third Animation or ProRes 4444 (millions of colors+) and export a self-contained QT file with Current Settings.
    blog: kyleesportfolio.com/blog
    twitter: @kyl33t
    demo: kyleewall.com
  • Tad Newberry
    June 22, 2012 at 8:09 pm
    Shane and Kylee, thanks for the reminder about going to 4444 (and don’t forget the “+”!). I liked working in FCP a little better, mainly because of what i could do with shadows that Motion wasn’t letting me do. Although, from FCP, i keep getting the graphic rendered with chunks of picture missing. Really weird. I’ll keep at it, but it’s off to a good start. Thanks again…
    FCS3
    6GB RAM
  • Neil Ryan
    June 26, 2012 at 4:47 am
    And makes sure your Timeline is NOT rendered before Export.
    Neil.
