Activity Forums Adobe After Effects possible to loop a precomp?
  • possible to loop a precomp?
    Posted by Eugene Hooper on September 27, 2009 at 12:53 pm
    Hey guys, I’m wandering whether it’s possible to loop the animation in a precomp or an imported video. I know that either one will only last for as long as the layer is visible, but I would like to know an alternative method to duplicating many copies of the same footage/precomp.
    Any ideas? Thanks in advance.
    Eugene
    Macbook 2.4Ghz Intel Core 2 Duo, 4GB RAM
    David Johnson replied 16 years, 12 months ago 3 Members · 2 Replies
  • Craig Hellen
    September 27, 2009 at 1:06 pm
    yup its easy here’s a link to a previous post
    https://forums.creativecow.net/archivethread/2/476790#476798
    Co-Director Podchains Ltd
    Video Producer / Motion graphics designer https://bexmedia.net
  • David Johnson
    September 27, 2009 at 8:28 pm
    The way Craig pointed to loops unrendered comps … you also mentioned imported footage … you can loop imported footage that way or in the interpret footage window … down at the bottom, there’s a box to type in the number of times you want footage to loop … that way, it’s looped to that extent anywhere you use it in the project without needing to re-apply that expression each time.
