Activity Forums Apple Final Cut Pro Legacy possible to lock a sequence in FCP?
  • possible to lock a sequence in FCP?
    Posted by Joe Murray on August 22, 2009 at 3:30 pm
    I know I can lock individual tracks within a sequence, but is there a way to lock a sequence in the FCP Browser window?
    Joe Murray
    Edit at Joe’s
    Charlotte, NC
    Elijah Lynn replied 16 years ago 4 Members · 3 Replies
  • Jeremy Garchow
    August 22, 2009 at 3:55 pm
    No, don’t think so.
    There’s a keyboard shortcut to lock all video and lock all audio tracks, though. Then you can just label the sequence red or something.
  • John Pale
    August 22, 2009 at 4:00 pm
    Not to my knowledge, but since you can lock files at the Finder level.. Perhaps you can copy the sequence you intend to lock to a new project and lock it… Or export an XML of the sequence and lock it. The XML option might be better, as match frame will continue to work (or will it? Need to test that)
  • Elijah Lynn
    September 16, 2010 at 8:27 pm
    I was just trying to do this same thing. Your workaround is helpful and I went to button list and found the keyboard shortcuts in case anyone else may find them useful.
    shift + F4 = locks all video tracks
    shift + F5 = locks all audio tracks
