Activity Forums Adobe After Effects Expressions Possible to link anchor point to distance?
  • Possible to link anchor point to distance?
    Posted by Greg Howell on May 5, 2016 at 8:04 pm
    Hi Guys,
    It’s probably less confusing if I don’t try to explain exactly what I’m trying to build. Basically, I need an expression that will tell layer A to change its anchor point value between 0px (min) – 200px (max) depending on the pixel distance between layer B and C. Although the max distance between B and C wont be 100px, it will be more like 1920px or something.
    If anyone can help, it would be greatly appreciated.
    Greg
    Kalleheikki Kannisto replied 10 years, 4 months ago 2 Members · 5 Replies
  • Kalleheikki Kannisto
    May 6, 2016 at 7:01 am
    This does what you describe. If you want the anchor point to change only in one direction (x or y), make the other return value 0.
    BC_dist = length(thisComp.layer("B").transform.position-thisComp.layer("A").transform.position);
    A_anchor = linear(BC_dist,0,1920,0,200);
    [A_anchor, A_anchor]
  • Greg Howell
    May 6, 2016 at 9:35 am
    Hi Kalle,
    Thanks for your response. Yes, I should of specified that it’s just the x axis i want to link the distance too. I cant get this to work. Is there any chance you could send over the project file so i could see it in action. that would be great.
    My email is: greghowell777@gmail.com
    thanks,
    Greg
    May 6, 2016 at 4:05 pm
    Ok, sorry I had the layer names wrong, I used A and B to control C instead of B and C to control A.
    Here’s the project file, AECC14.
    10064_moveanchorpoint.aep.zip
  • Greg Howell
    May 7, 2016 at 9:53 am
    Thanks Kalle. Could you post the expression please. I cant open the file because I have an older version of AE (im using cs6)
    cheers
    May 7, 2016 at 1:54 pm
    For layer “A” anchor point:
    BC_dist = length(thisComp.layer("B").transform.position-thisComp.layer("C").transform.position);
    [A_anchor, transform.anchorPoint[1]]
    Note that the layer names need to be “A” “B” and “C” respectively in order for this to work.
