Activity › Forums › Apple Final Cut Pro Legacy › Possible to edit HDV in the field?
Posted by Ming Saadprai on January 8, 2006 at 10:22 pmDoes anyone think it’d be possible to digitize and edit HDV in the field with a Powerbook and a couple of Firewire 400 drives?
Rozenberg replied 20 years, 8 months ago 4 Members · 4 Replies -
Thaxter Clavemarlton
January 8, 2006 at 10:40 pmIf you COULD, what would you do with the finished edit?
Kevin Monahan
January 8, 2006 at 10:40 pmShouldn’t be a problem. MIght want to get a cardbus adapter to add a second FireWire bus to separate the drives and deck.
Kevin Monahan
Take My FCP Master’s Seminar!
fcpworld.com -
Rozenberg
January 8, 2006 at 11:23 pmYep, You can use a powerbook to capture. I had a situation last summer that I had to capture 2 tapes (60 min) a day for 11 days on my 12 powerbook and a 250 LaCie. Since the 12″ doesn’t have a card slot I tried to capture with the disk connected to the USB 2.0 connection. It worked perfectly without any glitches!
_______________________________
Rozenberg
January 9, 2006 at 1:02 amOh, and yeah, i mean 22 1 hour HDV tapes..
