Possible to add points to a helix?
I want to animate shapes along a helix, but I also want to be able to join the helix to another spline path I create (so that the shapes get to the end of the helix, then travel along the custom spline I drew). I want it to appear seamless, so I don’t just want to place the helix close to the spline; I actually need the shapes to travel along the helix and spline as though they were a single path. My plan was to join them by a point, but the helix has no points and I was not able to use create point, like I normally would if I were adding a point to a custom drawn spline. Does anyone know if it’s possible to add points onto a helix, and if not, is there an alternative that would let me join the end of the helix to the beginning of a custom spline?
