Activity Forums Sony Cameras Possible Conflict with Record & Video Out
  • Possible Conflict with Record & Video Out
    Posted by Whit Prophet on February 16, 2016 at 2:56 pm
    Good morning
    We are using Sony NX5U as one of our cameras for streaming a hockey game.
    1. We send the video out via the SDI port 1080
    2. We simultaneously record on a SDHC card
    a) When we record at 720 there are no issues
    b) When we record at 1080, my guys say the video appears jittery in our streaming broadcast.
    Could/should there be any correlation between the recording format and effect on the streaming feed via SDI ?
    The SDI video out goes to an ATEM TVC mixer
    Whit
    John Lenihan replied 10 years, 6 months ago 3 Members · 2 Replies
  • Jeff Pulera
    February 16, 2016 at 8:35 pm
    Most, if not all camcorders, will output 1080i interlaced video, even if set internally to record 1080p progressive video. The interlaced output is for compatibility with displays.
    So, my guess would be that the streaming encoder is not liking the interlaced 1080i source? Your 720p output would of course be progressive.
    Jeff Pulera
    Safe Harbor Computers
  • John Lenihan
    February 16, 2016 at 9:45 pm
    I agree with Jeff, and will add my observations.
    I have had experience with doing what you are doing And, the black magic mixer you are using.
    1. The Broadcast standard for television is either 1920 x 1080 x60i OR 1280 x 720 x 60p. It never defined an output for 30p.
    The Sony NX5U is set to give you one or the other of those outputs, which at that time seemed to be the most compatible with broadcast TV. And still is, by the way.
    You can see that right in the menu of the camera, in the output section, it says vertical 1080i or 720p.
    2. The Black Magic is a great little mixer for the price. HOWEVER, everything has to be the same, inputs, and probably outputs too. It is not like the more expensive ones, that can frame convert on in real time.
    3. When I had a similar problem, trying to sync the output to a switcher which was also had an input from a computer, I found the following worked.
    a. I set up the NX5u for downconvert the output in squeeze mode(4×3)
    b. Then we connected the sdi cable to the mixer.
    c. We told the mixer the signal was really wide screen aspect ratio, and it made it 16×9.
    The net result was that the mixer was happy, people could see the live video and the computer, even though it was not full high definition. But I was recording in 1920 x 1080.
    I suspect the same thing for you. The streaming world is full of lies. They call high definition to sizes and bit rates which are less than high definition. If you truly tried to send it at full high definition, it would be choppy and blocky to 90% of the recipients.
    John
    John Lenihan
    LeniCam Video Productions
    https://www.lenicamvideoproductions.com
