Activity Forums Adobe After Effects Possible bezier warp
  • Possible bezier warp
    Posted by Cody Campbell on September 25, 2007 at 7:28 pm
    I was wondering if there was a way to distort an object kind of in the manner that bezier warp does — only instead of using the points that bezier warp gives you, is there way to use an imported path or a mask shape?
    Just curious
    _cody
    Just because noone understands you does not make you an artist
    Mike Clasby replied 18 years, 11 months ago 3 Members · 4 Replies
  • John Dickinson
    September 25, 2007 at 7:41 pm
    If you’re using AE 8 you could use the Puppet Pin Tool, its much more powerful than the standard Bezier Warp.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Cody Campbell
    September 25, 2007 at 7:53 pm
    puppet is good, however, its my outer edge thats important. What Im trying to do is form a clip of fire to an OM symbol — just masking it looks cheesy — if i could get my clip to wrap, warp, or squeeze into that space i’d be much happier
    _cody
  • John Dickinson
    September 25, 2007 at 7:56 pm
    How about trying the Reshape effect…
    JD
    John Dickinson
    Motionworks
  • Mike Clasby
    September 25, 2007 at 8:43 pm
    Like John said, Reshape should do the trick, just draw 2 masks on the Fire layer(set to none); 1) source mask (around your original fire and 2) Destination Mask (The shape you want it to become (logo shape)), then Percent to 100%.
    Here is a tut for the fine-tuning of Reshape. It was for a face morph, probably more than you need, but it’s great for tips on adding and adjusting “correspondence points”:
    https://library.creativecow.net/articles/zwar_chris/morph.php
