Activity Forums Adobe After Effects Expressions Position/scale backslide first keyframe
  • Position/scale backslide first keyframe
    Posted by Jim Hartnett on November 7, 2014 at 4:54 pm
    I’m trying to do sort of an inertial bounce in reverse. I’m sliding a logo on the X-axis. I would like it to slide back slightly on the 1st key-frame before it moves to the 2nd. Sort of like taking a step back before jumping forward. Any ideas??
    John Gardner replied 9 years, 4 months ago 3 Members · 3 Replies
  • John Gardner
    April 14, 2017 at 12:11 am
    Hi Jim,
    Did you ever find a solution to your question? I happen to be looking for a similar expression, so I’m curious if you found anything.
    John
  • Steve Sierra
    April 27, 2017 at 3:33 pm
    I think this works if you put it in the x Position of your layer (seperate dimensions first) :
    var Speed = 50;
    var backUpAmount =300;
    if(time<6/Speed ){
    Math.cos(time*Speed )*backUpAmount;
    }else{
    time*Speed*backUpAmount – 5*backUpAmount;
    I’m not sure why “6” and “5” work, but they seem to…. Must have something to do with the time cos takes to do a cycle…
    Hope this helps ????
    Cheers !
  • John Gardner
    May 2, 2017 at 7:01 pm
    Thanks Steve!
