Activity Forums Adobe Premiere Pro Positions of layers move when I close out of Premiere Pro. Why?
  • Positions of layers move when I close out of Premiere Pro. Why?
    Posted by Ryan Elder on March 13, 2018 at 4:54 am
    I am working on a special effect for a short film in Premiere Pro that requires several layers of video. However, when I put all the videos in the positions I want, and then save and close out of Premiere, then re-open it to work on it more then next day, all the positions have moved.
    I am not sure what happened so I put all the positions back to where I had them approximately as I could then saved and closed out of it again. I went to work on it the next day and all the layers were moved back to the positions that the programmed moved them to again after saving and reopening.
    So the program is going to keep on moving them back if I save and close out of the program. Does anyone have any idea what could be causing this to happen, so I can fix it?
    Thanks. I really appreciate it :).
    Ryan Elder replied 8 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
