Activity Forums Adobe After Effects Position/Keyframe Velocity
  • Position/Keyframe Velocity
    Posted by Julie Mullins on December 10, 2015 at 6:19 pm
    Hi!
    I’m trying to get a custom ease on position keyframes. I can’t use the graph editor, but am also kind of at a loss on how to edit without it (just using the keyframe velocity numbers).
    Can someone explain to me speed/influence and how to get it to look smooth? I’ve just been putting numbers in and doing it by trial and error, but that takes too much time and I still don’t really understand what I’m doing. I tried to follow this: https://dribbble.com/shots/1723793-Keyframe-Velocity making the top number stay the same for the outgoing and incoming and just the percentage changes, but it still doesn’t look quite how I want. I must be doing something wrong.
    Julie Mullins replied 10 years, 8 months ago 2 Members · 3 Replies
  • Julie Mullins
    December 10, 2015 at 7:12 pm
    Doesn’t seem to work for position keyframes. It shows up in the graph editor, but I can’t use bezier handles. Maybe it handles temporal and spatial properties differently?
  • Ken Teutsch
    December 10, 2015 at 8:19 pm
    As for the velocities… I’m not an expert.
    But have you tried separating the position dimensions (right click on position, choose “Separate Dimensions) to make them controllable in the graph editor?
  • Julie Mullins
    December 10, 2015 at 10:47 pm
    That works! Thank you! 🙂
    I’d still like to understand the keyframe velocity panel as well if anyone could explain.
