Activity Forums Apple Final Cut Pro Legacy positioning multiple text clips with wireframe?
  • positioning multiple text clips with wireframe?
    Posted by Finbar Taub on June 27, 2011 at 8:39 pm
    So i have multiple text clips in a timeline, and i want to move them all at the same time to position them. I would like to use the wireframe to get them where i want them – ive tried selecting multiple text clips, but then when i go to wireframe in the viewer it only moves the text clip that the playhead is on- any ides? Thanks so much –
    Jeff Greenberg replied 15 years, 2 months ago 3 Members · 4 Replies
  • Cody Walters
    June 28, 2011 at 2:46 pm
    Move your first text to the position that you want. Then copy that clip and paste the basic motion attribute to the other clips. If your ancore point is the same with all your text clips they should be all the the same location.
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • Jeff Greenberg
    June 29, 2011 at 4:54 am
    You can only make Multiple adjustments to clips under the playhead. Using the copy/paste method that Cody pointed out is your best solution.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Finbar Taub
    June 29, 2011 at 5:46 pm
    sorry for such a newbie question, but how do i paste the attributes into the clip? I copied the one clip that had the location I wanted, then tried to do the “paste attributes ” from the rt click menu onto another clip, but it did not change that clips location attribute –
    thanks a ton –
  • Jeff Greenberg
    June 29, 2011 at 5:50 pm
    Did you click any of the checkboxes like Basic Motion?
    Best,
    Jeff G
