Activity Forums Adobe After Effects Expressions Position Vector Offset
  • Position Vector Offset
    Posted by Jamie Bradshaw on July 8, 2009 at 7:37 pm
    Hi all.
    I think this should be obvious but my head is a bit fried from work at the moment.
    I’m looking for an expression that offset’s a 3D layer’s position along it’s local Z-axis by a certain amount (determined by a Slider).
    So is there an easy way to determine this if I have the following:
    pos1 = transform.position;
    orient1 = transform.orientation;
    posOffset1 = effect(“posOffset”)(“Slider”);
    Jamie
    JimJam•Graphics
    https://www.jimjamgraphics.com/
    Dan Ebberts replied 16 years, 10 months ago 2 Members · 1 Reply
  • Dan Ebberts
    July 8, 2009 at 11:35 pm
    This should work under most conditions:
    v = toWorldVec([0,0,1])*posOffset1;
    if(thisLayer.hasParent){
    value + parent.fromWorldVec(v);
    }else{
    value + v;
    Dan
