Activity Forums Adobe After Effects Expressions Position point to rotation value
  • Position point to rotation value
    Posted by Madli Man on January 2, 2013 at 2:58 pm
    Hi again,
    I found this code from mr.Dan, that calculate point position to rotation.
    Here is my situation, “OtherComp” sized 1920×1080.
    animated keyframe x 0 to another keyframe x 1920
    i would like to link this point i to ccsphere y rotation, but it cant get it rotate at last key point.
    it give only 114.6 degree. it rotate not end to end. 🙁
    Thank you.
    madliman
    x = comp("OtherComp").layer("line").effect("Write-on")("Brush Position")[0] /// X=0,Y=540
    360*x/(Math.PI*width)
    Dan Ebberts
    replied 13 years, 8 months ago
    2 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    January 2, 2013 at 7:21 pm
    I think you just need to change the last line to this:
    360*x/width
    Dan
  • Madli Man
    January 3, 2013 at 12:56 am
    Thank you very much mr.Dan,
    code work for X position, but why cant we put same code to Y as height?
  • Dan Ebberts
    January 3, 2013 at 2:21 am
    For y, I guess it would be like this:
    y = comp(“OtherComp”).layer(“line”).effect(“Write-on”)(“Brush Position”)[1];
    360*y/height
    Dan
  • Madli Man
    January 3, 2013 at 2:38 am
    Dan, here is my file i would like to do.. for Y i think it work great. X rotation i tried to do so.. please guide me mr.Dan..
    5150_mappointing.aep.zip
    Thank you
  • Dan Ebberts
    January 3, 2013 at 5:08 am
    Sorry, I’m not sure what it is that you’re trying to do.
    Dan
  • Madli Man
    January 3, 2013 at 11:13 am
    anyway thank you for X rotate code Dan. 🙂
    madliman
  • Dan Ebberts
    January 3, 2013 at 4:06 pm
    I’m not sure if this is what you’re looking for, but it may help. These expressions should keep the sphere oriented so that the brush position is centered.
    // shpere’s x rotation
    y = comp(“Comp 1”).layer(“Worldmap.jpg”).effect(“Write-on”)(“Brush Position”)[1];
    (y – height/2)*180/height
    // sphere’s y rotation
    x = comp(“Comp 1”).layer(“Worldmap.jpg”).effect(“Write-on”)(“Brush Position”)[0];
    (width/2 – x)*360/width
    The key is that the span for the x rotation is only 180 degrees.
    I hope that helps.
    Dan
