Activity Forums Adobe After Effects Expressions Position over time relative to width of comp
  • Position over time relative to width of comp
    Posted by David Lennox on April 22, 2013 at 12:06 pm
    Hello
    I’m trying to find an expression that will control the position of a layer over the time of the comp relative to the width of the comp.
    So move layer from x=0 to x =100% the width of the comp over the length/time of the comp.
    I looked into thisComp.width and thisComp.duration but keep hitting dead ends. Any help appreciated, thanks.
    Lukasz Pason replied 11 years, 5 months ago 4 Members · 3 Replies
  • Mitch Mann
    April 23, 2013 at 1:54 pm
    After separating dimensions for your X & Y, here’s your X expression:
    myCompWidth = thisComp.width;
    myCompDuration = thisComp.duration;
    myCurrentTime = time;
    myPercentageIntoComp = myCurrentTime/myCompDuration;
    myResult = myCompWidth * myPercentageIntoComp;
  • Kevin Camp
    April 24, 2013 at 4:18 pm
    i often use linear() to translate between unlike values like these… in this case time to position…
    x = linear(time, 0, thisComp.duration, 0, thisComp.width);
    [x, value[1]]
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Lukasz Pason
    March 27, 2015 at 6:13 pm
    In case you need to clamp you can do this.
    start = effect("start")("Slider");
    end = effect("end")("Slider");
    cTime = linear(time, 0, thisComp.duration, 0, thisComp.width);
    x = clamp(cTime, start, end);
    x
    Motion Designer / DJ / Father
    http://www.lukaszpason.com
    http://www.krop.com/lukasz
