Activity Forums Adobe After Effects Position not following the position keyframes
  • Position not following the position keyframes
    Posted by Brendon Sulesky on August 5, 2013 at 3:03 pm
    Hey, sorry to bother you. I’m running after effect cs4 and photoshop cs6 on a 32 bit computer. I have been working on an intro for my youtube gaming channel for the past couple days. I’m going for a motion graphics intro, so I made all the layers in photoshop cs6 and then imported the PSD file into after effects. I then proceeded to moving the layers positions in the ways I wanted them by adding keyframes, and after a bit I noticed that one of the layers would follow the keyframes 1-2 perfectly but when it got to keyframes 2-3 then it would start by going in the total opposite direction then continue to keyframe 3. I guess I should say that keyframe 3 was in the opposite direction of 1-2 so maybe there was a glitch saying to continue in the first direction, cause there are no keyframes stating that it should do that. If anyone knows what to do then please help.
    Brendon Sulesky replied 13 years, 1 month ago 3 Members · 4 Replies
  • John Cuevas
    August 5, 2013 at 4:39 pm
    It’s because of the use of Bezier keyframes. If you turn on the motion paths, you will see the over shoot. If you select all your keyframes, right click on them and change the spatial interpolation to linear you, it will correct the problem.
    Check out these tutorial for a lot more information: AE Keyframe Boomerang Effect,
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Emmanuel Jimenez
    August 5, 2013 at 5:26 pm
    It’s your keyframe interpolation. Select the keyframes you have that are giving you trouble, right click and go to Keyframe interpolation, click linear.
    Should solve your issue. Let me know if it works!
    I rock.
  • Brendon Sulesky
    August 8, 2013 at 3:55 pm
    Thank you! that worked! Sorry for the late response, I have been busy with chores.
  • Brendon Sulesky
    August 8, 2013 at 3:57 pm
    Yes, thank you that fixed it.
