Activity Forums Adobe After Effects Expressions Position Move on layer’s inPoint from multiple variable specified Coordinates randomly per layer?
  • Position Move on layer’s inPoint from multiple variable specified Coordinates randomly per layer?
    Posted by Gerald mark Soto on March 23, 2018 at 3:29 pm
    Okay so what i want to do is have have a grid of 20 boxes (100×100 pixels). And I want the boxes to slide into a grid formation from their inpoints. I would arrange them into a perfect grid but then i would like the inpoint to animate them into that perfect grid. Meaning i would like each layer to random choose to come from the top, bottom, left or right axis then settle into place. And I would like for the move to be specific to a range of movement, lets say 100 pixels in any direction. is that possible? I know about making expression for inpoints. But how do you make multiple variable for inpoint expressions.
    Gerald mark Soto replied 8 years, 3 months ago 2 Members · 5 Replies
  • Dan Ebberts
    March 23, 2018 at 4:09 pm
    Something like this maybe:
    easeTime = .5; // ease into postion over .5 second
    easeAmt = 100;
    seedRandom(index,true);
    offset = random() < .5 ? [easeAmt,0] : [0,easeAmt];
    offset *= random() < .5 ? 1 : -1;
    t = time - inPoint;
    value + easeOut(t,0,easeTime,offset,[0,0]);
    Dan
  • Gerald mark Soto
    March 23, 2018 at 6:02 pm
    PERFECT !!!! Thanks again.
  • Gerald mark Soto
    April 9, 2018 at 9:56 pm
    Is it possible to add the same in point animation to the out point. So it randomly comes in and it randomly comes out.
    Thanks Again sir.
  • Dan Ebberts
    April 9, 2018 at 10:19 pm
    easeAmt = 100;
    if (time < (inPoint+outPoint)/2){
    t = time - inPoint;
    }else{
    seedRandom(index*1001,true);
    t = outPoint - time;
    Dan
  • Gerald mark Soto
    June 4, 2018 at 5:27 pm
    Had another query,
    How can I apply this same animation but instead of using the inpoint of the layer to activate, it moves randomly with layer markers. So if I have 2 or 3 layer markera on the layer, it would move 3 times in either an X or Y position move?
    Here is what I got:
    sx = 100; // slide distance
    sd = .25; // slide duration
    offset = random() &lt; .5 ? [sx] : [sx];
    offset *= random() &lt; .5 ? 1 : -1;
    m =marker;
    x = 0;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (time &lt; m.key(n).time) n--;
    if (n > 0){
    t = time - m.key(n).time;
    x = ease(t,0,sd,(n-1)*offset,n*0);
    value + [x,0]
