Activity › Forums › Adobe After Effects › position keyframes in 3d comp problem
  • position keyframes in 3d comp problem
    Posted by Grayson Sedory on April 20, 2010 at 8:16 am
    HI, Im trying to move a precomposed title in Z space. When I make my first Keyframe move, everything is fine. However, Once i make my next move which is just a smaller move in the Z direction closer to the camera, the animation goes crazy. The Title flies into the camera and behind it in z space and finally comes back to the position that I keyframed. Its as if there is a Huge curve on the graph however there i no curve on the graph, just a straight like as the keyframe should give. Any help would be greatly appreciated, im using CS4.
    Grayson Sedory replied 16 years, 5 months ago 2 Members · 2 Replies
  • Steve Roberts
    April 20, 2010 at 12:29 pm
    Try setting the keyframe interpolation (spatial) to those two keyframes to “Linear”. Check the Help.
  • Grayson Sedory
    April 24, 2010 at 4:12 am
    I haven’t had time to try out what you said, however I just wanted to update you with the work-around that I used. I used Seperate xyz on that layer and that ended up working fine.
    In a different comp today I found that I had the same issue and again Seperate XYZ fixed it. Very strange, however, at this point a work-around will do.
