Activity Forums Adobe Premiere Pro Position keyframes get deleted when text is modified in mogrt
  • Position keyframes get deleted when text is modified in mogrt
    Posted by Hilary Tsai on July 19, 2022 at 6:42 am
    I created a lower thirds mogrt with some position keyframes, but when I use it in Premiere, every time I change the text, it appears to delete those keyframes. Furthermore, there’s some stuttering when I try to play it back after modifying text. However, when I scrub through, it shows the animation. The thing is that when I close the file and reopen it, the animation comes back with the text changes. I personally wouldn’t bother too much, since I know I can get it back by restarting the file. Since it’s client work, it makes me nervous though. I don’t know if this is a Premiere thing or if I did something wrong when I made the mogrt. Is this a known issue? I’m using AE 2021 and Premiere 2021.
    Hilary Tsai replied 4 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
