Activity Forums Adobe After Effects Position Key Frame BUG. Argggh!
  • Position Key Frame BUG. Argggh!
    Posted by Brandon Marrero on March 7, 2017 at 10:00 pm
    I made several key frames to make the red glowing circles stick to his pupils. After I made a pre-comp it made all of my key frames move off of his eyes. I already saved the project and cannot use the undo button. How can I fix this?
    Michael Menefee replied 9 years, 6 months ago 2 Members · 1 Reply
  • Michael Menefee
    March 7, 2017 at 10:09 pm
    When you make a pre-comp you select whether to leave attributes in the main comp or to be moved into the pre-comp. No matter what you selected, those keyframes arent deleted.
    If the keyframes are in the precomp, try selecting them all, copying, and then pasting on the pre-comp in the main comp. Vice-versa on the other way around.
