Activity Forums Adobe After Effects Expressions Position from two layers, plannar positioning
  • Position from two layers, plannar positioning
    Posted by Tim Harris on January 25, 2017 at 3:31 am
    I found a Fusion expression that I would like to know how to implement in Ae if possible.
    It requires two point that can then be used interpolate a 3rd point that is adjustable.
    It would be very useful for tracking.
    The Fusion expression and example can be found here;
    https://www.youtube.com/watch?v=kyaTJmmOmQ8
    Thanks kindly.
    Tim Harris replied 9 years, 7 months ago 3 Members · 3 Replies
  • Dan Ebberts
    January 25, 2017 at 6:32 pm
    I’m not sure how you want to implement this in AE, but it might be as simple as an expression like this:
    s = effect(“Slider Control”)(“Slider”);
    a = thisComp.layer(“A”).transform.position;
    b = thisComp.layer(“B”).transform.position;
    linear(s,0,100,a,b)
    Dan
  • Emre Anil
    January 25, 2017 at 8:01 pm
    Setup:
    P3 layer has Slider Control renamed to “weight” and adjusted value to 0 to 1
    Expressions for copy-paste:
    Weight Text – Source Text:
    w = Math.round(thisComp.layer("P3").effect("weight")("Slider") * 100) / 100;
    "w=" + w;
    Weight Text – Position (used anchor point for positioning):
    thisComp.layer("P3").transform.position
    P3 (3rd Point) – Position:
    w = effect("weight")("Slider");
    p1 = thisComp.layer("P1").transform.position;
    p2 = thisComp.layer("P2").transform.position;
    x = ((1 - w) * p1[0]) + (w * p2[0]);
    y = ((1 - w) * p1[1]) + (w * p2[1]);
    [x, y];
    Beam Effect – Starting Point:
    Beam Effect – End Point:
  • Tim Harris
    January 26, 2017 at 9:01 am
    Emre Anil,
    Thank you so much for taking the time to post your solution, which works perfectly :-).
    This will be very useful.
    Kind Regards,
    Tim
