Activity Forums Adobe After Effects Expressions position collision detection to scale output expression
  • position collision detection to scale output expression
    Posted by Olly Bea on November 12, 2008 at 4:07 pm
    Hi all
    I am trying to write an “if / else” type expression but I am obviously doing something wrong. I want a 3d text layer to scale up to 200% when it hits the position co-ordinates [545,506,0.0] but at all other times be 100%.
    How do I write it?
    Any help would get me out of a sticky hole!
    Cheers
    Olly
    Justin Sweeney replied 12 years, 10 months ago 3 Members · 9 Replies
  • 9 Replies
  • Dan Ebberts
    November 12, 2008 at 4:42 pm
    You probably want something like this:
    threshold = .01;
    if (length(transform.position,[545,506,0.0]) < threshold){ [200,200,200] }else{ [100,100,100] } Dan
  • Olly Bea
    November 12, 2008 at 5:32 pm
    Thanks Dan
    I’ll give this a whirl, but here is the interesting final step…
    Is there a way to say as the 3d text gets within say 10 pixels of the magic position [545,506,0] that it will gradually scale something like 10% per pixel?
    Many thanks Dan you are the king!
    Olly
  • Dan Ebberts
    November 12, 2008 at 5:49 pm
    I’m thrown by the “per pixel” part. If you’re just talking about scaling the text layer up as it’s anchor point approaches the target position, you could do it like this:
    transDist = 10;
    target = [545,506,0];
    d = length(transform.position,target);
    mult = ease(d,0,transDist,1.1,1)
    value * mult
    Dan
  • Olly Bea
    November 12, 2008 at 6:10 pm
    Sorry, didn’t mean to confuse.
    I am trying to create the effect that, as the 3d text layer nears the exact position [545,506,0.0] it scales up the closer it gets, so as it reaches exactly that position it will be 200%. Does that make sense?
    For example; the 3d text layer has a scale of 100% and a position of 445,506,0 (100 frames off, on the x axis) but as it animates near the exact position [545,506,0.0], it scales up. So that by the time it reaches the exact position it is 200%.
    Therefore using the figures in this example every 10 pixels it gets closer to the exact position it will scale up 10%.
    Or does this just confuse further?
    Olly
  • Dan Ebberts
    November 12, 2008 at 6:39 pm
    Well, if all you want to do is scale up as the layer approaches the target position, with a fixed transition distance of 100 pixels, this should work:
    transDist = 100;
    mult = ease(d,0,transDist,2,1)
    value * mult
    However, if the transition distance depends on the initial position of the layer, it gets trickier, and you’d need something like this:
    transDist = length(transform.position.valueAtTime(0),target);
    value * mult
    This second version won’t do anything until you actually keyframe the layer moving towards the target.
    Dan
  • Olly Bea
    November 13, 2008 at 8:20 am
    Thanks Dan both these work a treat.
    I’ll try and work out what is going on in each expression, I might have to come back to you with how each one works, because these look a little out of my depth.
    Many thanks for your help… once again!
    Olly
  • Justin Sweeney
    November 1, 2013 at 8:43 pm
    Hi Dan – long time listener, first time caller.
    I’m trying to modify this particular script to use a null object’s position to change multiple shape layers’ scale.
    All shape layers that have this script grow as the null approaches them, but instead of referencing the null as a single point (x and y position), I’m trying to scale the shape layers along the null’s y axis so no matter where I move the null on the x axis, all shape layers above and below will be scaled.
    Thanks for your help!
    transDist = 200;
    target = thisComp.layer("Dot Target 01").transform.position
    mult = ease(d,0,transDist,3,1)
    value * mult
  • Dan Ebberts
    November 1, 2013 at 10:10 pm
    Like this maybe:
    transDist = 200;
    target = thisComp.layer(“Dot Target 01”).transform.position;
    d = Math.abs(target[0]-transform.position[0]);
    m = ease(d,0,transDist,3,1)
    value * m
    Dan
  • Justin Sweeney
    November 4, 2013 at 2:20 pm
    Thanks, Dan, that’s exactly what I was looking for!
    For future reference, would there be a way to use the null’s rotation to control the scale effect on an angle?
    Justin
