Activity Forums Adobe After Effects Expressions Position changes on the scale of the layer
  • Position changes on the scale of the layer
    Posted by Mac Lad on September 1, 2018 at 7:40 am
    Hi Awesome Peoples;
    I am animating a graph which has a bar(rectangle) and point(circle) which is on the upper edge of the bar. The bar is scaling from 0 to 100 in the y-direction. I tried an expression in the position of the point but it does not follow the bar to its total length.
    For a basic idea of my layer and position
    x=thisComp.height;
    sy=thisComp.layer("bar").transform.scale[1];
    m=x-sy;
    [transform.position[0],m];
    Mac Lad replied 8 years ago 2 Members · 2 Replies
  • James Ronan
    September 1, 2018 at 5:22 pm
    If your circle layer has it’s anchor point centered you could try this expression on it’s position property:
    L = thisComp.layer("bar");
    r = L.sourceRectAtTime(time,false)
    L.toWorld([r.width/2,r.top]);
  • Mac Lad
    September 5, 2018 at 10:22 am
    Thank you so much!!! that really helps man…I am new to scripting and especially new to “toWorld” expression. Made a few tweaks on my side to work as I needed. Final expression is bellow
    r = L.sourceRectAtTime(time,false);
    s=L.toWorld([r.width/2,r.top]);
    [value[0],s[1]];
