Activity Forums Adobe After Effects Expressions position change at in point
  • position change at in point
    Posted by Jeremy Mullen on August 3, 2010 at 9:14 pm
    How can you set an expression for a parameter like ‘position’ that is active from a layer’s in point? I have dozens of layers that I want to originate from the same position, but at their respective in-points, I’d like to tell them each to move to a new position, so there will be something of a cascading effect as they appear. (Their in points are staggered down the timeline).
    Any and all advice is welcome – thanks!
    Jeremy Mullen replied 16 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 3, 2010 at 9:51 pm
    The are multiple ways to deal with timing based on in point. Here are a couple:
    // move from startPos to endPos over 1 sec
    startPos = [100,100];
    endPos = [300,300];
    moveDuration = 1;
    linear(time,inPoint,inPoint+moveDuration,startPos,endPos)
    // move from startPos at vel pixels per second
    vel = [200,200];
    t = time – inPoint;
    startPos + t*vel
    Usually, as in the second example, the key is to create a variable (“t” in this case) that equals the time since the in point and use that wherever you would normally use time in your expression.
    Dan
  • Jeremy Mullen
    August 4, 2010 at 2:04 am
    That’s terrific – the second one is just right, since velocity allows me to work with a variable set of clips, rather than defining positions explicitly. How would I randomize the velocity values, however, so that the layers can be made to travel in multiple directions without entering different values in each expression?
    Thanks already!
