Activity › Forums › Maxon Cinema 4D › poser to ciname animation
  • poser to ciname animation
    Posted by Annapapa on August 3, 2005 at 2:45 pm
    Hi
    I wonder whether you can help me. I have a poser 5 animation –
    (a boy that walks in place)- and I have put it in ciname 9. I’ve used interposer for this, the demo version. My problem is how to make the walk, into a spline and how to create a walk cycle. the demo version of the plugin allows only certain frames of animation.
    Anna
    Simon Carlson-thies replied 21 years, 1 month ago 3 Members · 3 Replies
  • Samir Kharchi
    August 3, 2005 at 6:49 pm
    Hmm, not sure what you now need to know. We certainly cannot give you a step-by-step tutorial on how to animate a character 🙂 If you want to do it by yourself (I
  • Annapapa
    August 4, 2005 at 11:24 am
    Thanks for this. I have found a way to sort of “clone” the animation. my problem now is that at the beginning of the cloned part the object moves back into the beginning. The problem is that I can’t alter the path that’s been set in poser.
  • Simon Carlson-thies
    August 17, 2005 at 6:50 am
    Do you have a position track for the character root object? If so you should be able to change the path of the object. Unless the position of the character is tied to a spline. I must confess I have only used poser a little bit, and never interposer.
    Best of Luck
    Simon Carlson-Thies
