Activity Forums Maxon Cinema 4D Poser Mixer
  • Poser Mixer
    Posted by Yoondo on March 27, 2007 at 5:50 am
    In R9.5, the poser mixer was located under mocca. In R10 it should be under characters, right? I can’t seem to find it although I don’t do much character animation, but I sure can’t locate it anywhere.
    This isn’t as hard as I find it I’m sure.
    Thanks in advance.
    Yoondo replied 19 years, 5 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    March 27, 2007 at 4:19 pm
    Posemixer is now a tag, so you won’t see it in the Mocca menu. If you right-click on an object in the Object Manager you’ll find the tag in the “Character Tags” submenu.
  • Yoondo
    March 28, 2007 at 1:09 am
    Thanks for the reply, Adam.
    After I posted, I noticed that it was available as a tag but not as a menu item. Can you tell me if I need to place the tags on every pose or just on the default?
    Thanks again.
  • Adam Trachtenberg
    March 28, 2007 at 4:34 am
    [Y.D.] “Thanks for the reply, Adam.
    After I posted, I noticed that it was available as a tag but not as a menu item. Can you tell me if I need to place the tags on every pose or just on the default?”
    You just place the tag on the object that’s actually going to be deformed (not the default or the poses).
  • Yoondo
    March 28, 2007 at 7:56 am
    Thank you for your help, Adam.
    Best,
