Activity Forums Adobe After Effects Pose 2 Pose with ONE SLIDER controlling a Layer with Multiple Sliders (And therefore: keyframes)
  • Pose 2 Pose with ONE SLIDER controlling a Layer with Multiple Sliders (And therefore: keyframes)
    Posted by Wouter Dijkstra on May 8, 2019 at 4:46 pm
    Hi everyone!
    I’m making a complex Mouth Rig using Sliders in Joysticks and Sliders. I now have 6 sliders which all give me a different mouth shape. Now I made keyframes on all 6 layers where each Slider at 100% gives a Mouth Shape, when the other Sliders are at 0%. I now want to make a pose to pose way of animating where I use one slider that refers to this combination of keyframes giving me a specific mouth position. I have seen tutorials on internet doing pose to pose, but in the cases I have seen it always has to Pass by other mouth shapes. I want to make direct movements from every mouth shape to another mouth shape.
    The thing I had in mind was linking this set of keyframes to a MASTER SLIDER, where value 1 gives me the combination of keyframes referring to for example: Slider 1 of the “ALL-MOUTH-SLIDERS-COMP”.
    Or another way (which I didn’t figure out yet) is to refer to the frame where is the combination of these 6 Sliders with ValueAtTime and make the MASTER layer link to this.
    Any suggestions?
    I am aware that the easy way is just to copy paste the 6 keyframes, but I like it to be more organised.
    example:
    Slider1: 100%,0%,0%,0%,0%,0% (open mouth)
    Slider2: 0%,100%,0%,0%,0%,0% (closed mouth)
    etc.
    Wouter Dijkstra replied 7 years, 4 months ago 3 Members · 13 Replies
  • 13 Replies
  • Wouter Dijkstra
    May 8, 2019 at 4:47 pm
    The way I did it now (if, else), there is no animation between the keyframes…. And I want to have a morph between the shapes. Not just “different images”.
  • Filip Vandueren
    May 8, 2019 at 9:22 pm
    Can you make a joystick and slider to control your different joystick and sliders ?
  • Wouter Dijkstra
    May 8, 2019 at 9:57 pm
    As it seems to me Joysticks and Sliders always gives for each ‘frame’ one slider. So it will give me 6 sliders again.
  • Walter Soyka
    May 9, 2019 at 9:20 am
    A lot of Ae rigs like this use time-remapping to let you choose a particular frame from a comp. When you animate a controlling slider from the pose in frame 1 to the pose in frame 3, it passes by the pose in frame 2.
    To have the mouth shape interpolate between two arbitrary mouth shapes, you have two options that I see:
    1) Build your mouth shape such that every pose of the mouth can be created by adjusting the same set of properties. Then we can use valueAtTime to get the value of each property at the outgoing and incoming pose, and have Ae interpolate between them. You’ll have to use the new Master Properties features and some expressions to “push” the pose value into the rigged comp.
    2) Animate all 30 transitions by hand (1-2, 1-3, 1-4, 1-5, 1-6, 2-1, 2-3, etc.) on the same timeline and use time-remapping expressions to “pull” the correct sequence from the rigged comp.
    Can you share the rigged mouth shape comp you’ve built?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Wouter Dijkstra
    May 9, 2019 at 12:30 pm
    Hi Walter,
    I was as a matter of fact experimenting with ValueAtTime, but still it only gives me the ‘exact’ value (1 frame) and I am not able to make an animation between the values controlled by one Slider. This specific Slider I have called “control”.
    I pasted the following code in each of the 6 sliders:
    x = thisComp.layer(“control”).effect(“Slider Control”)(“Slider”)
    if ((x>=1) && (x<2)) {[valueAtTime(framesToTime(0))];} else
    if ((x>=2) && (x<3)) {[valueAtTime(framesToTime(3))];} else
    if ((x>=3) && (x<4)) {[valueAtTime(framesToTime(6))];} else
    if ((x>=4) && (x<5)) {[valueAtTime(framesToTime(9))];} else
    if ((x>=5) && (x<6)) {[valueAtTime(framesToTime(12))];} else
    if ((x>=6) && (x<7)) {[valueAtTime(framesToTime(15))];} else 0
    I attached the RIG in this post.
    13327_mouthrig.zip
  • Filip Vandueren
    May 9, 2019 at 1:24 pm
    Then what happens if you animate your slider from 5 to 1: do you want it to pass through setting s 5,4,3,2,1 (similar to the behaviour that Walter described for Time-remapping) or do you want it to tween between the settings of 5 and 1.
    The latter can not be achieved by just 1 slider (unless you use hold-keyframes,n which defies the purpose ???? )
    you would need 3 sliders:
    fromPose
    toPose
    amount.
    and animating these 3 needs its own housekeeping, because fromPose and toPose should use hold keyframes and not change in the middle of when you’re animating slider 3.
    Then ach of your original 6 sliders would need something like
    [this is pseudo-code, won’t work yet)
    a=valueAtTime(fromPose);
    b=valueAtTime(toPose);
    linear(amountSlider,0,100,a,b);
  • Wouter Dijkstra
    May 9, 2019 at 3:03 pm
    Thanks Filip. So I would need 3 sliders. It makes sense what you are telling me! Thanks for this. But I suppose 3 sliders doesn’t give me de ‘fewer housekeeping’ that I was looking for. If this is the only solution, I suppose I have to stick to keyframing 6 sliders.
    I was hoping for a very nice and fancy way using only one slider. Would it according to you be possible like this –>
    Slider value goes from 1-10
    1 till 2 is the same as 100, 0, 0, 0, 0, 0 to 0, 100, 0, 0, 0, 0, 0
    It seems like it should to me. On the other hand all my tries gave me only absolute frames and no in betweens. Shouldn’t it be possible to create something like this with the linear expression that you are using as well?
  • Wouter Dijkstra
    May 9, 2019 at 3:04 pm
    Walter:
    This solution seems very close as well, but I’m not sure what the New Master Properties give me for options to make this. I would be grateful if someone could maybe elaborate this solution more. It seems to be the thing I almost had, except this will probably give the in-betweens as well.
  • Wouter Dijkstra
    May 9, 2019 at 4:04 pm
    just to add an alternative that would also make me happy:
    The control slider (just one) should function more or less like a button. Pasting 6 keyframes every time. If it would work like this there would be in-betweens as well. But still the question remains… how can I do it.
  • Filip Vandueren
    May 9, 2019 at 6:11 pm
    This works:
    this is the expression that each of your six sliders should get, change the first line accordingly.
    I have used a way of interpolating that will take into account the easing on your control-slider, so if you use eases or even hold-keyframes, that will all be reflect in the timing of the 6 controlled sliders.
    myIndex = 1; // number of the slider.
    sl=thisComp.layer("Null 1").effect("Slider Control")("Slider");
    if (sl.numKeys>1 && time>sl.key(1).time && time<sl.key(sl.numKeys).time) {
    nk = sl.nearestKey(time);
    prevK = nk.time<time ? nk : sl.key(nk.index-1);
    nextK = sl.key(prevK.index+1);
    fromValue= (prevK.value == myIndex) ? 100 : 0;
    toValue= (nextK.value == myIndex) ? 100 : 0;
    if (prevK.value<nextK.value) {
    linear(sl.value, prevK.value, nextK.value, fromValue, toValue);
    } else {
    linear(sl.value, nextK.value, prevK.value, toValue, fromValue);
    } else {
    sl.value == myIndex ? 100 : 0;
