Activity Forums Apple Final Cut Pro portrait effects to fill the screen
  • portrait effects to fill the screen
    Posted by Patrick Donegan on December 4, 2015 at 2:41 am
    How do I create that effect of rolling out the edge pixels all the way to the edge
    on a portrait aspect picture or a movie someone created on an iPad
    in the portrait mode?
    I have seen it before and just cannot remember the name of that effect.
    Thanks so much!
    Patrick Donegan replied 10 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Noah Kadner
    December 4, 2015 at 4:53 am
    Not quite sure what you’re asking but scale and crop in the Inspector are probably what you’re looking for.
    Noah
    FCPWORKS – FCPX Workflow
    FCP eXchange – FCPX Workshops
  • Patrick Donegan
    December 4, 2015 at 7:11 am
    I don’t want to just call it up or crop them, as they are 4:3 slides and all have information on
    them.
    I have seen the effect on tv news when they show someone’s phone footage,
    and in music videos.
    I want to fill in the right and the left of each slide with something easy.
    Thanks.
  • Mark Suszko
    December 4, 2015 at 5:11 pm
    Seems like we’re talking two things here: video shot in vertical portrait mode, and older video shot landscape but in the old NTSC 4×3 aspect ratio.
    Ideas:
    Sample the most prominent color in the vertical or 4×3 image, make that a color solid on the layer below, add a vignette or gradient to that.
    or
    Duplicate the original vertical clip, put it behind/below the original clip, add Gaussian blur and scale it up to fill the 16×9. Try it with a soft drop shadow on the 4×3 clip for a variation.
    or
    Throw up multiple copies of the portrait-styled vid, side-by-side. If you make three, throw a blur and partial crop on the two side copies, vignette the center copy to draw the eye to it.
    or
    Scale the vertical clip and rotate/distort it to look like it’s playing at an angle. Heck, go whole-hog: grab a still of a cell phone, map the video to its screen, then angle the resulting composite with a blurred background behind it.
    or
    Map the video into the screen of a stock image of an old TV set, use the TV set art to fill the 16×9.
    or
    Depending on what part of the content has the important content, if it was shot 2K or 4K, maybe you can re-crop it to 16×9 and blow it up.
    or
    install in the client’s phone an app like Horizon for iOS that forces a landscape view no matter what the camera orientation is, called:
    or
    Locate a gobo arm from your studio. Apply it to the photographer’s skull, repeat until they learn to shoot in landscape mode.
    Not familiar with the edge pixel effext in the request, but there are TV distortion effect plug-ins with a sub-effect called “scrape” that would grab the pixels and smear them across the screen. Similar effect to using horizontal blur.
  • Mark Suszko
    December 4, 2015 at 5:28 pm
    A follow-up; If these graphics are powerpoint slides, it is easy to go back into powerpoint and have it re-format them into the right aspect ratio and re-export them, in just a couple of menu clicks. Check them to see that the text and images re-wrapped correctly, but generally any problems are few and minor. Ultimate product will be higher quality in the edit than if you just distort them on the timeline.
    Failing that, it’s easy to make or download a free Photoshop batch action that will go thru a folder of images and re-scale/format all of them to the new aspect ratio, in minutes.
  • James Taylor
    December 5, 2015 at 7:21 am
  • Patrick Donegan
    December 6, 2015 at 8:04 pm
    Great!
    Thanks – I bought this now and am about to use it for this project.
    It is not exactly what I imagined, and it is close enuf that it will save me some time.
    The effect I would like to still find is the one that takes the last few pixels of the right
    and left edge and explodes it out.
  • Patrick Donegan
    December 6, 2015 at 8:05 pm
    Thanks for all these tips. I just printed them out and will review them each time
    I am ready to mess with vertical format pictures.
