Porting Files
Posted by Jeff Kohn on April 14, 2005 at 6:08 amI have about 60 gigs of video clips from which I’d like to select segments to port from my desktop to an external drive where I can then work by laptop. I don’t want all the material on the external drive – only a few gigs of it where I would then do the real project editing. How would that best be done? Thanks
Rob Mack replied 21 years, 5 months ago 4 Members · 6 Replies -
Gary Kleiner
April 14, 2005 at 6:22 am -
Jeff Kohn
April 14, 2005 at 6:31 amThanks Gary, but won’t this trim my original footage? I’m too scared to do that. I want essentially to “copy” the trimmed to the external while leaving the original footage as is. How would I do that?
Gary Kleiner
April 14, 2005 at 6:35 am -
Jeff Kohn
April 14, 2005 at 6:57 amI do a “save as” with copy and trip option and “create trimmed copies” selected. AVICODEC reports the copied file to have a loss of quality – here’s what I get for the copy (with loss of 10% quality):
File : 4.43 MB (4.43 MB), duration: 0:00:01, type: AVI, 0 audio stream(s), quality: 88 %
Video : 4.40 MB, 36842 Kbps, 29.970 fps, 720*480 (4:3), dvsd = Sony Digital Video, Supportedand here’s the original
File : 27 MB (27 MB), duration: 0:00:07, type: AVI, 1 audio stream(s), quality: 98 %
Video : 26 MB, 31579 Kbps, 29.970 fps, 720*480 (4:3), dvsd = Sony Digital Video, SupportedAlso, must the wav be separated from the video portion? Can that be prevented?
Edward Troxel
April 14, 2005 at 1:33 pmTry this instead:
1) Put the pieces you want to keep on the timeline
2) File – render as – DV-AVI (PAL or NTSC)
3) Render that to the external driveThis will give you ONE file on the external drive containing the clips you want to keep.
I am also assuming the original clips are DV-AVI. If that is the case then the segments will simply be COPIED to the external drive. However, you’ll need to manually split the large clip into segments on the Vegas timeline (where as Gary suggested they would still be individual segements – just consist of TWO files each, one for video and one for audio)
And, yes, there ARE other ways as well. For instance, you could create regions around the individual pieces and then use a script to render each region to a separate file. etc…
Rob Mack
April 15, 2005 at 5:27 amThe multirender tool in Veggie toolkit would probably do it and give you individual clips. I think there’s also a setting to add more head and tail. I think there might be a demo of it available at the peachrock site.
There may be other scripts that are free.
The Save-As tool in Vegas isn’t so great. I don’t really see why it has to render as wav64, but it does. It’ has always seemed to me like a vestigial tail in Vegas.
Rob Mack
