Activity Forums Apple Final Cut Pro Legacy ‘Portable Plug-ins’ – repost
  • ‘Portable Plug-ins’ – repost
    Posted by Max Frank on July 11, 2005 at 3:24 pm
    It looks like I may have to continue editing my documentary overseas. Now, since it’s impossible for me to shlep my G5, I’d like to just take my entire project on my FWHD, and use the company’s G5 when I get to my destination.
    The problem is:
    My machine & project has Magic Bullet, Boris & Digital Heaven plug-ins – and the machine I’m going to be using won’t have those plug-ins installed.
    Is there a way for me to bring my plug-ins with – and use/install them on the new machine?
    Wayne
    2DP G5, 3.5GB RAM, FCP HD
    Max Frank replied 21 years, 2 months ago 5 Members · 6 Replies
  • Arnie Schlissel
    July 11, 2005 at 3:38 pm
    Read the licenses for each of those plugins. Most likely, they will require you to purchase new licenses if you want to install them on a 2nd machine. If the only Boris plugins you use are from Calligraphy, those are bundled with FCP, & Digital Heaven’s plugins are so cheap that it shouldn’t matter. But Boris Red, Continuum & Magic Bullet are all kinda pricey. Which mac will you be finishing the doc on? That’s the system that really needs the plugins.
    Arnie
    https://www.arniepix.com
  • Digihead
    July 11, 2005 at 3:49 pm
    You could clone your startup disk to an external firewire hard disk and use that as your startup disk at your destination. That way you’ll have everything that your home-based computer has.
  • Graeme Nattress
    July 11, 2005 at 4:01 pm
    Arnie, you’re right on there! If you are using the plugins on another persons’s machine, then the chances are the they’re not licenced for that machine and the online facility needs to buy copies for their machine if they are to remain legal.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Arnie Schlissel
    July 11, 2005 at 4:07 pm
    [Graeme Nattress] “Arnie, you’re right on there!”
    I have my moments. 🙂
    Arnie
  • David Jones
    July 11, 2005 at 4:39 pm
    Or since you are still editing your documentary, just cut it together
    and worry about finishing plugins at the last stage.
  • Max Frank
    July 11, 2005 at 6:19 pm
    Thanks to all of you who took the time to write in.
    I’ve got a bit of a better picture now.
    Wayne
