Activity Forums Apple Final Cut Pro Legacy Portable harddrive for FCP
  • Portable harddrive for FCP
    Posted by Lauren on March 25, 2007 at 9:01 pm
    I am about to go on a two month trip and need to be portable (and light) with my editing set up (I usually edit on a G5 tower but will have to adjust to a laptop…)
    I have a MacBook pro with FCP 5.1 and have been looking into getting a portable harddrive. I noticed that most of them are 5400rpm which I remember being a nightmare from years back – endlessly dropping frames at that speed. Has anything changed with these drives over the years? Does FW 800 make a difference?
    Or, do I need to buy a 7200rpm drive – the only one I have seen so far is the 100gb lacie rugged.
    If the 5400 is OK that would be preferable as I can get more storage at less cost…
    I am traveling with a new Canon HV20 and will probably be shooing with the HD mode (I hate to leave my DVX-100 at home but it is just so gigantic and I will be moving around a lot).
    Thanks for any thoughts.
    Lauren
    Mohd. Fauzi replied 19 years, 5 months ago 7 Members · 6 Replies
  • 13 Create COW Profile Image
    13
    March 25, 2007 at 10:11 pm
    because the Canon HV20 is only HDV any firewire drive should be fine, but personally i would look into getting a esata raid and accompanying sata card for your express slot.
  • Walter Biscardi
    March 25, 2007 at 10:21 pm
    [Lauren] “Or, do I need to buy a 7200rpm drive – the only one I have seen so far is the 100gb lacie rugged.”
    Yes, 7200 is far better than 5400, especially if you plan to really fill up the drive. I’d recommend something like a LaCie FW800 unit.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Shane Ross
    March 25, 2007 at 11:12 pm
    The G-Raid Mini is also 7200 RPM, and is bus powered.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • David Smith
    March 26, 2007 at 3:30 am
    You’ve gotten some good suggestions, just a couple of other thoughts to keep in mind:
    Tests at barefeats.com show some interesting comparisons between 5400 and 7200 rpm drives. Walter is right to point out how much drives slow down when they fill up, however that very reason is pointed out in the barefeats test to show that larger capacity 5400 rpm drives can often be faster in real world situations when you are sticking to portable designs. It comes down to how much you want to spend.
    If you can only afford single drives and you want the 2.5″ form factor, I think you’re limited to 100GB if you want a 7200rpm drive. You can get a 160GB 5400rpm drive for less money. If you have say, 70 or 80GB of data already on the drive, the 5400 drive is actually faster at that point, since it’s a little over half full while the 100GB drive is at 70 or 80 percent capacity.
    I went with a 160GB, 5400rpm Hitachi drive in a transinternational Minixpress box:
    https://www.transintl.com/store/category.cfm?category=2643
    It’s got USB 2, Firewire 400 and Firewire 800 interfaces. You can buy the case bare, or they sell a selection of drives installed. It was actually cheaper to buy the drive from them. It’s also bus powered which I love. No power brick to carry around, and no need for an a/c source to be able to use it.
    The G-Raid mini is also a great choice if you have the money. Lacie also makes a bus powered, two drive array. These are great as you can have both large capacity and 7200rpm drives. They are, naturaly, a bit bigger and heavier.
    Firewire 800 makes a BIG difference in read/write speeds, but only the latest Macbook Pro machines have a FW800 port. You can get an expresscard adaptor, but you may not be able to use a bus powered drive through it. I bought a cardbus card for my Powerbook G4 and it does NOT power the drive.
    Regards,
    David
  • Mark Raudonis
    March 26, 2007 at 4:30 am
    I’ve got the G-Tech Mini. Love it! Tiny. Bus powered. Choice of USB or FW 400.
    Haven’t done sustained editing off of it, but sure is great for moving data from here to there.
    Mark
  • Mohd. Fauzi
    March 27, 2007 at 10:45 am
    I’ve been using 1 Terabyte Lacie HD with MacBook Pro for my editing job for the past 3 weeks and so far everything runs smooth (no drop frames) just like I was doin my edit on G5. I also added another 1 Terabyte Lacie HD (Both connected through FW800). Still no big difference.
