Activity Forums Blackmagic Design ” Port Error” with Premiere 2.0 Tryout, BM-Driver 5.4 and Sony Digital-Betacam PLayer ( Pal)
  • ” Port Error” with Premiere 2.0 Tryout, BM-Driver 5.4 and Sony Digital-Betacam PLayer ( Pal)
    Posted by Oliver Petz on February 3, 2006 at 2:57 pm
    Hello Blackmagic-Team!
    After installation Premiere 2.0 Tryout and the new BM 5.4 Driver for testing, i am
    unable to start the capture-mode( shorcut F5)
    A window appears:
    ” Port Error.Check that selected port ist available or not in use by another prozess”
    After that Premiere has to terminated with taskmanager. (Unable to close the
    capture-mode)
    There is a DIGIBETA Player connected to Decklink Serial Port( Sony DVW-A510P),
    PAL-Resolution . Do you have tested your new driver with ” Pal-Machines”? I remember:
    There was a some Problems in the past with Decklink Extreme and
    Pal-Digibetas-Machines( wrong Frame-offset during capture and so on…)
    Thanks a lot for help
    Oli
    Tony Partam replied 20 years, 7 months ago 3 Members · 4 Replies
  • Oliver Petz
    February 3, 2006 at 3:04 pm
    I forgot:
    In Premiere 1.5 the new Driver ( 5.4) works fine!
    ( no ” Port Error”)
  • Shane Chadder
    February 4, 2006 at 2:08 am
    I’ve noticed with Premiere 2.0 (unlike 1.51) we have to set it to use com 3 for 422 in order to use the decklink card. I guess there are 2 com ports already on the motherboard.
  • Oliver Petz
    February 4, 2006 at 12:07 pm
    Hi Shane !
    the two serial ports are disabled in the BIOS-Setup because i do not need them.
    (Mainboarde Asus A8N-SLI Premium )
    Today will try again to capture again in PPro 2.0 with ” enabled” serial ports in Bios.
  • Tony Partam
    February 7, 2006 at 1:45 pm
    Have the same issue here…
    Control was working on 1.5 but not anymore on 2.0 tryout.
    Me too i disabled com ports on bios.
    Tell me what you find out
