Activity Forums Boris FX Particle Illusion porblem with emitters in stage window
  • porblem with emitters in stage window
    Posted by Jmk on June 28, 2005 at 1:34 pm
    I added emitter to the stage window, then changed tool to select tool. When I want to add another emitter from library window, but I can’t. Indicator doesn’t change to emitter sign, it shows the pointer sign all along. Is there a way to fix it?
    Elvis Deane replied 21 years, 2 months ago 2 Members · 1 Reply
