Activity › Forums › Adobe After Effects › Popping up many dots
  • Popping up many dots
    Posted by Tad Marsik on May 9, 2016 at 4:43 pm
    Hello, first of all thank you for this forum. It helped me a lot since I’m learning in After Effects.
    Now I’ve got into a trouble because I can’t find a solution on the internet and I can’t think of something… normal.
    Let’s say I have this background. It was made with halftone function in Photoshop.
    https://i.imgur.com/HJt7bnV.png
    I’d like to make an intro with identical background and those circles to be animated. Like popping up from 0% scale.
    Is there an easier way how to do it in After Effects? I started with AE a few days ago so I came up only with making every single circle and change sizes manually.
    Thank you for responses, I really appreciate it.
    View post on imgur.com
    Richard Herd replied 10 years, 4 months ago 3 Members · 2 Replies
  • Joseph W. bourke
    May 9, 2016 at 6:27 pm
    This tutorial might help you out:
    https://lesterbanks.com/2014/03/create-easy-halftone-effect-ae-using-shape-layers-camera-lens-blur/
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Richard Herd
    May 9, 2016 at 7:00 pm
    You can animate it with shape layers and a repeater. If you have you used expressions before, modifying a “drag me” expression on the radius or scale parameter will get you there too:
    //applied to a blur effect, for example, causes the blur intensity to increase as the to points get closer;
    point1=transform.position;
    point2=thisComp.layer("dragme").transform.position;
    delta=sub(point1,point2);
    distance=length(delta);
    linear(distance, 0, 80, 40, 0);
    I can’t remember where I got the dragme expression, but I didn’t write it.
