Activity Forums Web Design (WordPress, Joomla, etc.) Pop Up Video ( kind of like a hologram )
  • Pop Up Video ( kind of like a hologram )
    Posted by Alexander Palmer on July 5, 2012 at 2:40 am
    Hi Cow ppl,
    I have seen video that pops up on websites ( usually a person )
    either from the bottom or just central within a page
    here’s a bit of an example on this site https://www.chrisbray.net/photography.php
    and I can’t work out how to do it
    Love it if someone can help out ??? !! don’t even know what this effect is called
    Do u use After Effects ?? a Plug In ?? or Final Cut ??
    Love some help on this
    even if its just … what the effect is called
    cheers
    alex
    Demetri Tashie replied 14 years, 1 month ago 2 Members · 3 Replies
  • Demetri Tashie
    July 10, 2012 at 1:06 am
    this is basically a transparent SWF ( i.e. Flash with a transparent alpha channel).
    one basic workflow :
    – shoot video against a green screen
    – ‘erase’ ( ‘key out’) the green screen background in your video editor
    – export movie with transparent alpha channel
    – bring video into Flash
    – publish the swf as a tranparent background
    – embed swf onto html page, with a wmode parameter of transparent
  • Alexander Palmer
    July 26, 2012 at 1:46 am
    thanks demetri
    what is “flash” ??
    and what is SWF ??
    and what is “wmode parameter” ?
    these feinitions would be helpful
    cheers
    alex
  • Demetri Tashie
    July 27, 2012 at 1:16 am
    FLASH is a major software and developiong platform, extrememly popular in webwork, although since it is not supported on iPhone or iPad, it is becoming less used. It was THE platform for delivering video in the web for a long time.
    Flash programs output a file with the extension .SWF
    this is usually called a ‘flash movie’ (since flash used to be mainly an animation tool) , though it is not to be confused with video, which can be incorporated or compiled to play inside the .swf
    WMODE parameter, to say it simply, is used in the code that puts the swf into your webpage. it’s most common usage is to create transparency for the swf, so that the background of the webpage can show through ( and thus in the example, the person seems to be floating on top of the webpage)
