Activity Forums DaVinci Resolve Pop out scopes window problem (see image)
  • Pop out scopes window problem (see image)
    Posted by Duke Sweden on December 5, 2017 at 1:24 pm
    I had Resolve set up to where when I pop out the scopes panel it showed up in my second monitor. I previously had a 4K main monitor but switched it out for a 1080p. No problem then. When I put the 4K monitor back, the scopes panel on the second monitor got huge and can’t be moved (see image). I can’t grab it to move it back to the main monitor. I can’t do anything to it. Any ideas on how to fix this (the second monitor is set correctly to 1080p, etc.)
    If I have to reinstall Resolve I’ll do it but hopefully it won’t come to that.
    Dell XPS 8920
    Intel i7 core 7700 build
    GeForce GTX 1050ti
    32 Gigs of RAM
    3 7200 RPM SATA Drives
    Windows 10 64-bit
    DaVinci Resolve 14.0.1
    Duke Sweden replied 8 years, 9 months ago 3 Members · 6 Replies
  • Tero Ahlfors
    December 5, 2017 at 1:31 pm
    Reset UI layout under the workspace menu.
  • Duke Sweden
    December 5, 2017 at 2:03 pm
    Thanks, Tero, but that didn’t fix it.
    EDIT: When I tried it the second time with the scopes window open, it repositioned it in my first monitor. I can move it around, etc. but if I drag it back to the second monitor it’s too big. I could swear I didn’t have this problem the previous time I used the 4K as a primary monitor, but maybe I wasn’t using scopes back then. Anyway, your solution did enable me to move the scopes back to the main monitor, a lot better than it was before.
    Thanks again, Tero.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Ole Kristiansen
    December 5, 2017 at 7:31 pm
    Hi Duke !
    I have the same problem – have a Dell 32 “4K main monitor scaling to 150% and a 21.5” 1080 monitor to display scopes on in Davinci Resolve! I just do scopes less with the arrow in the bottom right corner ! Then I drag scopes over to my 1080 monitor – and can adjust again with the arrow !
  • Duke Sweden
    December 5, 2017 at 10:28 pm
    Hey Ole!
    “I just do scopes less with the arrow in the bottom right corner !”
    Not quite sure what you mean by that. For some reason my scopes window is now back to normal size on my 1080 monitor so I’m all good, but if you could explain what you mean by doing scopes less with the arrow I’d appreciate it, in case I run into problems in the future.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Ole Kristiansen
    December 6, 2017 at 5:57 pm
    Hi Duke !
    “I just do scopes less with the arrow in the bottom right corner”
    I think it was a bad Google translation !
    I just resize the Scopes Window, with the arrow in the bottom right corner, before I move it to my 1080 monitor and then I can expand it again as needed
  • Duke Sweden
    December 6, 2017 at 6:45 pm
    Oh ok, you mean when you place your cursor into the corner it becomes an arrow. I was looking for a little arrow icon in the right corner. Yeah, you have to do it in the primary monitor first right? Because once it’s in the secondary monitor I can’t resize it.
    Thanks for the proper translation 😉
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
