Activity Forums Zaxwerks Poor render quality in after effects once output is done
  • Poor render quality in after effects once output is done
    Posted by Jesse Perez casanova on July 31, 2014 at 8:07 pm
    Hey there guys, a friend of mine gave me your program to use, its so awesome and easy to use, the only problem is when I have created my file and output it to after effects, the quality is very poor
    Edward Wu replied 12 years, 1 month ago 2 Members · 1 Reply
  • Edward Wu
    August 1, 2014 at 9:14 pm
    Hi Jesse,
    Which version of our software are you using and which product is it? Are you using 3D Invigorator PRO or ProAnimator?
    One thing you can do is to check the Output panel and see what AntiAlias setting you are using. If you are not using AntiAlias, be sure to set it to 3×3 or higher. If you are using ProAnimator version 8, set the AntiAlias setting to Best and see if that helps.
    Best,
    Edward
