Poor quality when i trim and then make movie
Posted by Andrew Taylor on June 13, 2019 at 12:01 pmHi
I created a webcam video of in mp4 format from a logitec camera
I took it into vegas in mp4 format and trimmed it
(there does not seem to be an uncompressed file available)But when i produce movie in vegas, the quality is very poor
How can i improve the quality?thanks
AndrewAndrew Taylor replied 7 years, 2 months ago 2 Members · 3 Replies -
Graham Bernard
June 13, 2019 at 12:14 pm[Andrew Taylor] “How can i improve the quality?”
Hi Andrew! I thought your issue sounded familiar:
https://forums.creativecow.net/thread/24/1023299
So, nothing changed?
* Grazie
Cameras: Canon XF300 + PowerShot SX60HS Bridge -
Andrew Taylor
June 13, 2019 at 12:36 pmI captured a widescreen mp4 from my webcam at 17k bps.
So do i need to set vegas at the same 17k bps?
There does not seem to be an option to select bps in production in vegas.Just so i undertand, it’s ok to import trim then export an MP4?
(not that i have a choice because webcam creates an mp4 to start with) -
Andrew Taylor
June 14, 2019 at 9:43 pmGeneral
Complete name : C:\Users\Andrew\Videos\Logitech\LogiCapture\2019-06-13_11-06-28.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/iso6/mp41)
File size : 23.8 MiB
Duration : 1 min 18 s
Overall bit rate : 2 561 kb/s
Writing application : Lavf57.66.102Video
Format : AVC / AVC / AVC / AVC / AVC / AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L4 / Baseline@L4 / Baseline@L4 / Baseline@L4 / Baseline@L4 / Baseline@L4
Format settings : 1 Ref Frames / 1 Ref Frames / 1 Ref Frames / 1 Ref Frames / 1 Ref Frames / 1 Ref Frames
Format settings, CABAC : No / No / No / No / No / No
Format settings, Reference frames : 1 frame / 1 frame / 1 frame / 1 frame / 1 frame / 1 frame
Format settings, GOP : M=1, N=25 / M=1, N=25 / M=1, N=25 / M=1, N=25 / M=1, N=25 / M=1, N=25
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1 min 17 s
Bit rate : 2 393 kb/s
Width : 1 920 pixels
Original width : 1 920 pixels / 1 920 pixels / 1 920 pixels / 1 920 pixels / 1 920 pixels / 1 920 pixels
Height : 1 080 pixels
Original height : 1 080 pixels / 1 080 pixels / 1 080 pixels / 1 080 pixels / 1 080 pixels / 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 24.305 FPS
Minimum frame rate : 6.250 FPS
Maximum frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0 / 4:2:0 / 4:2:0 / 4:2:0 / 4:2:0 / 4:2:0
Bit depth : 8 bits / 8 bits / 8 bits / 8 bits / 8 bits / 8 bits
Scan type : Progressive / Progressive / Progressive / Progressive / Progressive / Progressive
Bits/(Pixel*Frame) : 0.047
Stream size : 22.2 MiB (93%)
Codec configuration box : avcCAudio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate : 175 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 1.63 MiB (7%)
Title : Mixed Audio
Default : Yes
Alternate group : 1
