Activity Forums Adobe Premiere Pro Poor quality render!
  • Poor quality render!
    Posted by Emma Payne on March 7, 2017 at 10:25 pm
    Hi there!
    I’m having a lot of trouble with a render. It’s rendering at a very low quality! Usually I have no trouble at all with premiere renders, but if you look at this video- https://www.youtube.com/watch?v=KUP33cBC1Gw&feature=youtu.be
    You’ll see that the render quality is dreadful.
    I used-
    H.264
    1920×1080
    24 fps
    Square Pixels
    Baseline
    4.1 Level
    Can someone please help? Thank you!!!
    Animator, Graphic Designer, Tea maker extraordinare <3
    Jeff Pulera replied 9 years, 6 months ago 3 Members · 3 Replies
  • Emma Payne
    March 7, 2017 at 10:55 pm
    I’ve also rendered it out at a PNG sequence, the quality is absolutely fine in the png images! I imported those back into premiere in an effort to render into a H.264, still the same issues.
  • Chris Wright
    March 7, 2017 at 11:01 pm
    are you using AME or premiere? adobe media encoder is better quality. increase your bitrate too.
  • Jeff Pulera
    March 8, 2017 at 3:29 pm
    Hi Emma,
    Nice animation work! If you can please post a screen shot of the Export Settings used that may be helpful in identifying the issue
    Jeff Pulera
    Safe Harbor Computers
