Activity › Forums › Audio › Poor quality render from Izotope RX5
  • Poor quality render from Izotope RX5
    Posted by Howard White on February 7, 2017 at 9:46 am
    Any ideas why the rendered files seem to be a lot worse than the playback in the software itself prior to rendering? I have found a solution but it is time consuming and wierd. Whilst RX5 does some amazing stuff, I am finding it is better not to render when I have done the work. Instead, I am getting a better result by just playing it, recording it in audacity, and exporting it from there! Otherwise, things like noise reduction are really not so good once you have exported. I am no export on output settings, but I am not using MP3 and the output files from RX5 are usually bigger than the original! So I do not think I am choosing something too compressive. Thanks.
    Howard White replied 9 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
