Activity › Forums › Adobe Premiere Pro › Poor Quality QuickTime DV-NTSC output
  • Poor Quality QuickTime DV-NTSC output
    Posted by Kevin Thorp on February 7, 2007 at 3:39 pm
    I need to submit a 3D animation in QuickTime DV-NTSC format (720×480, 30 fps), but I can’t seem to get decent quality out of Premiere.
    My 3D software can save the animated clips as uncompressed AVIs or sequentially numbered Targa or TIFF files. The quality is razor-sharp.
    After editing in Premiere I can save in various formats (including AVI, WMV and Apple Animation) and keep that excellent quality, but not with QuickTime DV-NTSC. Unfortunately this is the format I need.
    Suggestions?
    Kevin Thorp replied 19 years, 7 months ago 4 Members · 6 Replies
  • Vince Becquiot
    February 7, 2007 at 4:41 pm
    Did you go to QT player preferences and set the quality to high ?
    Vince
  • Vince Becquiot
    February 7, 2007 at 4:45 pm
    BTW, DV and motion graphics / animation aren’t meant to be mixed. DV is meant to compress video out of a camcorder, and that’s about it.
    5:1 compression on animation is always going to look pretty ugly.
    Cheers,
    Vince
  • Steven L. gotz
    February 7, 2007 at 5:16 pm
    For Quicktime, you are better off getting Sorenson Squeeze so that you have access to the Pro codec.
    Steven
    https://www.stevengotz.com
  • Kevin Thorp
    February 7, 2007 at 6:11 pm
    Wow… that fixed it. Thanks, Vincent!
    I assumed the problem was with Premiere, not a simple setting in the QuickTime player.
    I suppose there are better codecs for animation, but this is for a contest and the rules require QuickTime DV-NTSC. I guess that makes it easier for them to produce a compilation DVD from all the entries.
  • Blast1
    February 7, 2007 at 6:13 pm
    [Kevin Thorp] ” need to submit a 3D animation in QuickTime DV-NTSC format (720×480, 30 fps), but I can’t seem to get decent quality out of Premiere.
    My 3D software can save the animated clips as uncompressed AVIs or sequentially numbered Targa or TIFF files. The quality is razor-sharp.”
    If you are trying to view NTSC video on a computer monitor it will not look too good, Particularly fullscreen, you are dealing with a format best viewed on a external NTSC video monitor at the optimum viewing distance for the monitor size.
  • Kevin Thorp
    February 9, 2007 at 1:48 pm
    What confused me was the other QuickTime codecs played back fine, but not DV-NTSC. Until I took Vincent’s advice & changed the player’s settings.
