Activity Forums DVD Authoring Poor quality pixelated text in Menus using DVD Studio Pro.
  • Poor quality pixelated text in Menus using DVD Studio Pro.
    Posted by Mike Hayes on March 13, 2008 at 3:19 am
    Hi there,
    I’m using DVD Studio Pro. I create menus in Photoshop and export flattened .psd files.
    I work in PAL. This problem is worse in 16×9 (anamorphic).
    I create the menus at the true original res of 1024×576. When the menus are imported into DVD Studio Pro the text becomes jagged and pixelated. I understand that non-square pixels are causing this, but I don’t know of a solution.
    What is the best way to bring menus and text into DVD Studio Pro?
    I have searched a lot and noone has a great solution.
    Thanks heaps,
    Mike
    Girshon Rutstein replied 18 years, 5 months ago 4 Members · 3 Replies
  • Bouke Vahl
    March 14, 2008 at 4:13 pm
    ‘true’ 16 : 9 video is 720 * 576 in Pal, non-square pixels
    (same res as 4:3, other pixel aspect ration)
    In the latest versions of Photoshop, you can set it to non-square 16:9 Pal.
    Or, scale down the images in Photoshop to 720 x 576 before bringing them in DVD SP
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
  • Bridget O’leary
    March 25, 2008 at 12:06 pm
    Mike,
    I had a simular problem previously. After much searching on this site and Apple’s forums I found out that you can import PSD menus at a higher resolution than I first thought – 300dpi.
    Also what really helped was bringing the menu in as 720×576 and then setting the menu to 16×9 once imported into DVD Studio Pro. This meant I created the menu as a 1024×576 graphic, then resized it to 720×576 so it appears anamorphic ready for importing into DVD Studio Pro.
    One other small trick is to add a 1 – 3 pixel ‘blur’ in photoshop.
    Regards
    Bridget
  • Girshon Rutstein
    March 27, 2008 at 1:13 am
    Import Photoshop File into your Editing application. Create 5 sec movie and export as Animation Codec
    It will look great!
