Activity Forums Apple Final Cut Pro Legacy Poor quality output
  • Poor quality output
    Posted by Rich Franklin on February 9, 2012 at 8:04 pm
    Whatever settings I use in FCP, the output is very bad. I need to burn a DVD – done every export option and codec possible from FCP, maximum settings in Compressor but still the video looks compressed.
    The original footage is MXF DVCPRO 50, 720×576 to be output as 1024×576.
    Am I doing something wrong in Easy Setup?
    Michael Gissing replied 14 years, 7 months ago 4 Members · 3 Replies
  • Shane Ross
    February 9, 2012 at 8:41 pm
    Export a self contained Quicktime Movie…do not recompress. Bring into Compressor…choose the BEST QUALITY DVD setting, do not modify any setting. Take the result to DVD SP…author the DVD. That’s the best way to do it with FCS.
    [Rich Franklin] “The original footage is MXF DVCPRO 50, 720×576 to be output as 1024×576.”
    Wait…what? Why those dimensions? 1024? That could be your problem…
    Shane
    Little Frog Post
  • Richard Van harderwijk
    February 9, 2012 at 10:30 pm
    What are your settings exactly? HD (720)? Or SD anamorphic 1024×576?
  • Michael Gissing
    February 9, 2012 at 10:35 pm
    SD anamorphic is 720 x 576. This is what you need on a DVD.
    You only make 1024 x 576 when you want a 16:9 square pixel file for viewing on a computer. Never for DVD.
