Activity › Forums › Adobe Premiere Pro › Poor quality output on to DVD
Posted by Bruce Rutland on July 15, 2005 at 3:25 pmHi,
I posted a question here yesterday regarding poor quality output on to DVD. The question went as follows:
Aanarav Sareen replied 21 years, 2 months ago 5 Members · 7 Replies -
Scott
July 15, 2005 at 6:08 pmHi Bruce,
What encoding preset are you using in premiere?
Also, MiniDV is compressed at a 5:1 ratio – DVD is about 24:1 (or so). Even with the compression the DVD should look great. Make sure you are doing a 2 pass VBR encodong with at least 3 or 4 Mbps. This should give you more than satisfactory results.
Scott
Bruce Rutland
July 15, 2005 at 6:09 pmHi Creig,
Thanks for your comments.
I think it could be the quality of the AVI files. Is there any way to increase the quality when I capture within Premiere Pro or is there a software on the market to improve the quality?
I seem to also get quite a lot of blur and double image when there’s any movement on the DVD.
Still smiling,
Bruce.
Aanarav Sareen
July 15, 2005 at 7:52 pm[Scott] “MiniDV is compressed at a 5:1 ratio”
Isn’t MiniDV 4:1:1?
Aanarav Sareen
Adobe Certfied Expert, Premiere Pro
https://www.asvideoproductions.com/video -
Mark Weaver
July 15, 2005 at 9:25 pmAanarav,
NTSC MiniDV is 4:1:1. This is the colorspace subsampling
part of DV compression. The numbers represent (Luminence,
Chroma-Blue, and Chroma-Red).There is more to it beside colorspace subsampling and the
result is about 5:1 total compression for DV.Mark
Aanarav Sareen
July 15, 2005 at 9:37 pmAh! Thanks for the info Mark.
Aanarav Sareen
