Activity › Forums › Adobe After Effects › Poor quality of footage in nested composition?
  • Poor quality of footage in nested composition?
    Posted by Agstfl on September 24, 2006 at 9:06 am
    I’m having an odd issue at the moment – footage I bring in looks fine, but if I place it in a comp and nest that within another it appears severely aliased. All settings/quality are set to best, I just can’t seem to stop it from happeneing.
    Anyone have any ideas or encounter something similar?
    Daniel Martinez replied 20 years ago 4 Members · 6 Replies
  • Rafael Amador
    September 24, 2006 at 10:35 am
    This is just in the canvas, or when rendering as well?
    rafael
  • Daniel Martinez
    September 24, 2006 at 11:32 am
    Is the sources media compressed? MPEG? WMV?
  • Agstfl
    September 24, 2006 at 11:52 am
    Both on the canvas and when rendered.
  • Agstfl
    September 24, 2006 at 11:53 am
    Not really – Quicktime mov @ Animation 100%
  • Mylenium
    September 24, 2006 at 12:14 pm
    Maybe it contains fields and your footage interpretation is not correct?
    Mylenium
    [Pour Myl
  • Daniel Martinez
    September 25, 2006 at 8:25 pm
    I’m not experienced with QT animation. But checkout the field order of it. And make sure AE interpret it acordingly?
    Whenever I have a problem like that I divide and concour.
    Look at the QT is it good? If not then theres your problem.
    If it is ok – then try and load the QT into a comp and render it out. What happens?
    Is it good? If not, then you have a problem with the field order interpretation, or your render settings. Make sure the field order is kept cacordingly all the way through your workflow.
    If its good, then precomp the comp with the QT and render it. Is it not good – then do the same thing you just did with some other media. Try and find out if the error is consistant or only in relation to that specefic QT animation.
    If it’s the QT, the find on wich point it differs from you other media that worked and see if that would lead to a solution. And so on and so forth.
    I think your problem is not After Effects or the QT, but the way you face your problem. Look at it in steps and you’ll solve it.
