Activity Forums Adobe Encore DVD Poor quality menu
  • Poor quality menu
    Posted by Ryan Stone on January 3, 2013 at 12:13 pm
    I’m using Encore CS5 on Mac OS X to produce a DVD for a client. They’ve supplied me with a an SD Widescreen DVD menu at 1080 x 576 px. However, once built, and played on a computer, the menu is rather pixelated and unreadable.
    It looks fine on a TV, but I’ve seen other home-made DVDs that have a crystal clear menu. Any suggestions on what I’m doing wrong would be gratefully received,
    Ryan
    Jon Geddes replied 13 years, 8 months ago 4 Members · 4 Replies
  • Stan Jones
    January 3, 2013 at 1:49 pm
    PAL? NTSC or PAL, 1080×576 doesn’t work. Since CS4, PAL wide, square pixel equivalent, 1050×576.
    Stan Jones
  • Ryan Stone
    January 3, 2013 at 2:29 pm
    Sorry, yes of course that would have been some important information!
    It is PAL, so I’ll give your dimensions a go.
    Many thanks,
    Ryan
    Ryan Stone | Creative Director
    Lambda Films Ltd.
    Video Production & Marketing Company
    Retina Burn Blog
    Online Video, Film & TV Blog
  • Daniel Ludwig
    January 4, 2013 at 4:01 pm
    if your on pal you should use 1050×576 if you are working with adobe-products. if you are using apple DVD SP you should use 1024×576 (square px) and then scale it to 720×576 for your work or use a PAL 16:9-setting within photoshop, which will be 720×576 with anamorph pixel-aspec.
    cheers
    danny
  • Jon Geddes
    January 7, 2013 at 11:03 pm
    Once it goes on DVD, it will be 720×576 with anamorphic widescreen. Encore does a very poor job of scaling menus, so you will want to use Photoshop to scale to that size.
    1) Create a 720×576 PAL Widescreen document in Photoshop using the presets.
    2) Open your menu and drag all the layers into the new 720×576 document.
    3) Position into place and save as a new psd. All layers and button groups should have appropriate Encore prefixes.
    4) Import the new psd as a menu into Encore.
    This should look much better.
    Jon Geddes
    http://www.precomposed.com
