Activity Forums Adobe InDesign Poor quality jpegs in pdf
  • Poor quality jpegs in pdf
    Posted by Alistair Gallop on November 20, 2012 at 11:48 am
    I have thought this now for a while when using Indesign. I place a jpeg file within an indesign file and when I export it as a pdf I definitely loose quality. The images have not been scaled up – if anything I have reducing them in size on page?
    Any ideas?
    Alistair Gallop replied 13 years, 10 months ago 2 Members · 2 Replies
  • Dwayne Smith
    November 21, 2012 at 9:48 am
    Yes, absolutely — this is totally normal. That’s how you get PDFs with such a small file size.
    You can play around with image quality under the Compression tab in your export window. Experiment with both the Downsampling and Image Quality settings until you get the best balance between quality and file size for your requirements. Better quality = larger file.
    With downsampling, as a rough guide, 72ppi = screen quality, 150ppi = inhouse print quality, 300ppi = press quality — try various numbers in between.
    d.
  • Alistair Gallop
    November 21, 2012 at 3:20 pm
    Thanks for your replu Dwayne. What I dont understand is, that when I create a pdf from powerpoint / word etc – I never seem to get the same issues with jpegs / pngs?
    Seems to just arise when creating a pdf from indesign?
    Cheers
    Ali
