Activity Forums Adobe Premiere Pro Poor quality exports
  • Poor quality exports
    Posted by Jason Brown on December 9, 2014 at 5:49 pm
    I’m getting bad quality exports when using the quicktime mov format, as well as the h.264. I feel like Ive tried everything but the image doesn’t hold up compared to the source footage.
    Take a look:
    Footage was shot on the Sony A7s at 25fps 1080p. I’m exporting with Media Encoder CS6
    Source footage:
    This is the quicktime export:
    Settings for this:
    Format: Quicktime
    Preset: 1080i 25 h264 aac 48khz (1080i is the only option I have available, no 1080p??)
    Quality: 90
    Render maximum depth checked
    key frame every 1 frame
    limit 10,000kbps
    maximum render quality checked
    This is the h264 vimeo preset:
    Settings for this:
    Format: H.264
    preset: Vimeo 1080p 25
    profile: high
    level: 5.1
    render max depth checked
    vbr 2 pass
    target bitrate 10mbps
    max bitrate 12mbps
    key frame distance 1
    render max quality
    PC Specs:
    Windows 8.1 running CS6
    i7-4930k CPU @ 3.40ghz
    32gb RAM
    GeForce GTX 770
    Any advice/tips is massively appreciated!
    Ericbowen replied 11 years, 9 months ago 3 Members · 3 Replies
  • Steve Brame
    December 10, 2014 at 12:29 pm
    Search for ‘Quicktime Gamma Shift’, and you’ll find many solutions.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Jason Brown
    December 10, 2014 at 3:35 pm
    Thanks that seems to have improved the color, however I’m still seeing a lot of noise in my exports.
    Is there a way of getting a 1080p export from quicktime as oppose to 1080i?
  • Ericbowen
    December 10, 2014 at 6:28 pm
    Go down video tab and look under resolution for field order. Change that to progressive. If you select the 1080i preset you can make sure the resolution settings is already correct and just change the field order for progressive.
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
