Activity Forums Adobe After Effects poor quality export
  • poor quality export
    Posted by Ross Kidd on August 14, 2008 at 5:30 pm
    It is my first time using AE and I made a heart shape in illustrator and imported to AE. When I export as a SWF the quality is very poor even though I am exporting at maximum quality. Can any help?
    The image below shows the comp (left) and the swf export (right)
    https://blue-fly.co.uk/example.png.
    R.
    Tom Scott replied 18 years, 1 month ago 3 Members · 2 Replies
  • Brian Lehmbeck
    August 14, 2008 at 6:07 pm
    I could not see the example you put up… the link dosen’t seem to be active…
    but when I am working on a project that needs to be delivered as an SWF or FLV etc I typically don’t use AE to create them. I have found that exporting the highest quality video out of AE and then compressing using Sorenson works the best. It’s not that AE can’t necessarily handle it I just think the result is better.
    Brian
    System Specs:
    Avid Xpress Pro v5.7.5
    Window XP SP2
    HP Workstation xw4100 Pentium 4 2.60 GHz 2 gig RAM
    After Effects v7.0
  • Tom Scott
    August 15, 2008 at 2:04 am
    “I could not see the example you put up… the link dosen’t seem to be active… ”
    Take the period off the end of the link.
