Activity › Forums › Adobe Premiere Pro › Poor quality DVD when played on TV
  • Poor quality DVD when played on TV
    Posted by Hage2003 on February 14, 2007 at 7:24 pm
    I just got the program and messed around making a short little video with some footage I had from my MiniDV camera. I played it on my TV and the quality is terrible. Any ideas on what I did wrong?
    Hage2003 replied 19 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Vince Becquiot
    February 14, 2007 at 9:05 pm
    You may have to start by giving us some of your settings. Bit rate, total running time of the videos, field order, even a screen shot from a DVD player on your computer might help..
    Vince
  • Hage2003
    February 15, 2007 at 12:33 am
    MPEG 2 DVD
    NTSC 720×480
    29.97 drop frame
    CBR encoding
    7.0 mbps
    Field Order Lower
    GOP M Frames 3 N Frames 15
    I watched it on a Samsung 32 inch LCD HDTV
  • Vince Becquiot
    February 15, 2007 at 3:14 am
    Well, the settings seem fine. Did you export to DVD directly from Premiere ?
    Of course, watching a DV to DVD footage on an LCD screen is going to bring out many of the artifacts you may not see on a smaller screen, or on a regular TV.
    By “terrible”, do you mean noisy? It would be great if you could post a screen capture from your computer screen.
    Vince
  • Larry Melton
    February 15, 2007 at 2:41 pm
    Is the image being “upsized” to fit the HDTV screen? Your HDTV LCD is probably 1280 x 720 (or similar) so even if you have an upconverting DVD player, there’s a lot of digital manipulation going on to make it fill your TV. Try playing it on an SDTV and see if it looks better.
    Larry Melton
  • Hage2003
    February 16, 2007 at 1:57 pm
    It is upsized. It looks much better on a SD. Is there anything I can switch in Premeiere and burn another to make it look better?
  • Vince Becquiot
    February 16, 2007 at 3:57 pm
    Unfortunately, no. The quality will depend on the unit doing the upsizing, some do better than others. You could also export to progressive. That will improve the quality in some players / screens, but might also bite you on certain players..
  • Hage2003
    February 16, 2007 at 6:14 pm
    I’ll give it a try. Thanks for the help.
